have a nonstarting 88 2.0 mighty max. No spark - have replaced coil, distributor. need to know where ignitor is and could ballast resistor be problem? any othert idears welcome. Could ecu be issue?
mxmikie
check your timing belt
jayjay
timing checked - installed a new weber carburetor plus hand coke - need to know if the ECU could be interfering without the mikuni solex monstrosity - have no emmissions to worry about. replaced coil with new one - only other thing not checked is ecu ballast resistor??? how do I test that... new distributor and I am assuming the ignitor is in the distributor - am I wrong? Hayes no mention- have a wiring schematic that does not show it.. Fuel ok. Most likely something simple.. it ran for two days after I put the new carb in..Then refused to fire = it does crank and rotor turns..
mxmikie
when you turn the key on is the pos side of coil hot ???
jayjay
stupid question - which side is positive ?
jayjay
OK just put in third coil - everyone is telling me all this older rebuilt, Chinese, etc is defective - just turns over..
Now if I take my circuit testing light - a bulb in the middle of a wire - I get a light across the battery terminals and every terminal in sight including just grounding it and with key off - this tells me something is wrong>>> And stop with the timing belt - it is perfect and cannot affect the damm spark.. Grrrrrrrrr.. thank youa, Jay
