Max Engine \  Heeeeeelp! Exhaust manifold is driving me crazy.
Max Engine Max Tech
views 1999
replies 5
following 2
christopherasa   +1y
I'm looking for an exhaust manifold that will fit it my 1990 Ram 50 with the 2.4L engine (6G46 -Fuel Inj - SOHC). As I understand it, this 'build' was used on the Ram 50 in '90, '91, and '92. Are there other D50s, Rams, etc. that used the same manifold? It has the 2x2 ports [ 00 00 ] instead of the evenly-spaced ports [ 0000 ], with two ports leading into the exhaust pipe. Pardon my being pedantic: I'm new to all this and so am trying to be -- perhaps overly -- precise in what I say.
mxmikie   +1y
1987 to 1994 2.0 and 2.4 mighty max ram 50 d-50 with paired port will work
christopherasa   +1y
I'm a novice to all this, mxmike: by "paired port" you mean those vehicle's manifolds will work so long as the port spacing matches what my engine has, correct? (If not, I need an explanation of what "paired port" means.)
mxmikie   +1y
correct
christopherasa   +1y
Am indebted to you, sir. A sincere thank you.
mxmikie   +1y
MR224682.....
