Max Engine \  Tranny only working in 4th gear
Max Engine Max Tech
views 1740
replies 3
sirgaryhimself   +1y
So i have a 87 mighty max 2.0 5 speed I just put a tranny in it that was saposed to be "good" but in install it and the only gear that works is 4th. Same as the old tranny that i pulled from the truck. Im stumped. Clutch lets out fine in 4th gear. But when i put it in any other gear nuthing happens. Just a slight humm
mxmikie   +1y
is the shifter loose ??? are you missing the nylon bushing on the end of the shifter ????
sirgaryhimself   +1y
Shiter is tight and feels good. New bushing didnt fix anything. Even with the shifter off you can putnit in gear and nuthing happens other than 4th Im stumped.
rxinhed   +1y
Trans is toast, not the shifter. You have a broken guts and the only reason that 4th gear works is because Mitsu built the trans to fail in this fashion. The KM-145 trans for the 2.6L does the same thing. Time for a rebuild, sadly.
