Air Ride Suspensions \  Air cylinder setup for my winter beater civic..
Air Ride Suspensions Q & A
views 486
replies 0
following 1
phatzz   +1y
Well I got a 93 hatch painted flat black.. Its my beater for the winter so I dont have to drive my prelude. Also my daily drive. . here goes my setup..
12 Gallon 6x 1/2 Ports, 2x 3/4 Custom Ports
Valves= rear ups= GC 450 Extreme 3/4"The rest of the valves are SMC's 3/8=soon to be upgraded to 1/2 GC Extremes.All pressed Lines and JIC FittingsEAI Royal Blues in the front = 1/2 inchNO name 3 " Cylinders in the rear= ported to 3/4 inch top port
Furnas adjustable pressure switch w/ un-loader valve w/copper line to in-tank check valve.
SMC 1/2" Water TrapSMC 1/2" Oiler w/ pressed line to compressor Belt driven compressor w/ stainless 3/8 input /output lines on custom adaports for the compressor
Liquid Filled Pressure Gauge, Shradder valve,relief valve and all that stuff.
Front lines are 1/2 Pressed Gates lines Rear valve assembly is mounted on the top of the cylinder w/ 1" Preseed 1500 PSI Line with 3/4 Fittings to the tank.-Home made switch box.
I built this setup in my garage and hooked everything up in the past 2 days.. I will have pics up in a day or 2.
