NEED HELP!!
NEED HELP!!
FN
f n lo
Hey,
i know this should be in a different section but i need help to night as i am trying to get my truck ready for a safety this week...
GRillle/Headlamp Help! -does anyone have any pics or measurements for putting the 4runner grille and headlights in?? i know some mod. is needed and i dont wanna hack it all up to find out there is an easier/cleaner way...also what the best way to fab up a bracket for a 95 4runner bumper??its going on my 93 BTW....
EDC ( air comressos help) i have a air conditioning unit off of a 22re(same engine as my truck) from a 4runner and i want to know what is required to convert it to a edc?? also it looks like there is only 3 bolt holes on the left side of the enigne to make it fit?? anyone have any input??
That guys, im not a dumbass, or w.e. i just want to do things the cleanest way without the headache...
Anyhelp would be very appreciated!!thnx
oldsklminitrk
Ok what is a EDC? adn as far as fabbing a bracket just get the original ones they should bolt right on to the mounts.
FN
f n lo
ok EDC Engine Driven Compressor...using an ac pump for a air compressor, fast and high pressure.... but yea, i have the original brakets for my bumper but they dont fit the 4runner bumper....
no1lowr's avatar
no1lowr
you need 4runner bumper brackets, and as far as the front end swap, the grille should be very close and the headlights just make a tab for them to bolt to and wiring the pigails is not a hard task, just calm down and think it through.
FN
f n lo
someone told me oud had to cut the co support to make the headlights fit properly...and the grille doesnt line up very well.... anyone have any thoughts on the EDC??
W
wadds
if the compressor is like the ones that are on say Rodneys truck or duckys, all you have to do is tap the fittings out, they are already sized right for one to be a 3/8 and the other 1/2. Oldskl probably knows a little more about it, I'm just the assclown that has the thread taps.
oldsklminitrk
Ok I just call it a onboard air compressor.....I got it done on mine
FN
f n lo
koolkool, so just put it on see whitch ones pushs and whitch one pulls then hook up an oiler and oil/water sterater and im done?? kol thanx, just wasnt sure on that one.... Did anyone have anyluck with that 4runner shit?? the grille wants to stick out alot on the bottom, and one of the mounting brackets are broken on the headlights so i thihnk i have to buy new ones now:(:(:(im oing to try useing some plastic fusor.....yes i noe, im cheap...
lux15m
fitting the 4runner headlights, you have two options
1) Cut your current radiator support to fit the lights (hole has to be bigger)
2) Buy a 4runner radiator support panel.
I took option number 1.
Relax dude.
FN
f n lo
how much did you have to cut? i cut and bent a bit but they still wont fricken fit, lol..... any advice??
