Off-topic \  Horse Power, Check it out
Off-topic General Discussions
views 129
replies 0
following 1
OldSkoolCadillac   +1y
i alot of people seem to think that 4 cylinder hondas cant make alot of horsepower, i have a feeling this 3 cylinder snowmoilbe engine would be a better way to go
GEN-1518-VEP Genesis 1500/1800cc V.E.P.
PSI is always setting the standards in the Performance Industry and this 'Monster Max' Triple will set the standards for years to come. This 1500/1800cc engine is pure PSI gut wrenching HP. This motor has been on the Ice, Snow, Asphalt and Hillclimbs and has proven itself everywhere!
In '02/03 PSI's 1080cc Genesis Twins knocked the socks off the competitors Twin Engines last season. With such good success to work from, PSI's customers begged for a triple version of thathighly successful motor package! PSI obliged with an evenBigger is Better package. We lead while others follow.
There is more HP (350) and more Torque (over 215 ft. lbs.) than anyone really needs. But for you few that believe in maximum everything, this kit is for you. It will require you to have the best equipment to go with the biggest and baddest snowmobile engine ever built. It will require more than just a good chassis, billet clutch and a few extra dollars. It will require you to have a monster set of balls.
Seriously, this engine is very mild & tame at low speeds, but under hard accelaration, your eyes will water. If you can afford to do this job right, then you will ultimately own the fastest snowmobile on ice or snow, or climb the highest mountains with the most track speed ever seen. There is no equal, you are ultimately the baddestdude on snow.
If you still think this engine is for you, then lets get to the technical side. This 'Monster Max' 1800 utilizes PSI's new 100mm Monster Max Pistons that are uniquely shaped for maximum performance and reliability. These 100mm pistons are Swain Tech Coated and dropped into the trickest Hi-Performance cylinders in the marketplace. PSI's Genesis V.E.P. Cylinders incorporate the first 12 port snowmobile cylinder design that pumps out almost 120HP per hole. This unbelievable Genesis cylinder utilizes PSI's Patented V.E.P. System that was redesigned in '02 and went through 2 seasons with a perfect record!!
PSI's incredible 12 port cylinder and patented VEP System is covered with PSI's patented 'Dial-A-Dome' system that allows quick adjustments to compression changes in minutes or less.
This awesome Genesis Top-End sits on top of a 3 cylinder Sand Cast Custom case that utilizes a custom built pinned, welded and balanced Crank. This Crank is ideal for this engine because it is very heavy duty, much like a Harley crank. Then a 3 cylinder ignition is fitted to the crank and crankcase, along with a water pump and pull starter. This PSI Genesis Engine comes completely assembled with ignition system and exhaust system. The customer supplies reeds, carbs, and a Billet Clutch, along with the knowledge that you will decimate your competition.
