Mini Truckin General \  Update on the 4.6 conversion mazda
views 230
replies 0
following 2
burbanlegand   +1y
Well I finally have been home long enough to work on the mazda for once. The new flywheel and clutch are in. I installed all externals and only found one flaw. The starter solenoid was barely touching the lower arm support right next to the frame. I notched it for clearence just incase I ever need to change the starter. The fire wall mods are finished and in the morning the modded mazda clutch pedal box will go back in. The throttle cable amazenly enough hooked right onto the mazda gas peddal with out any mods!! The engine/tranny should be back in on sunday. I now just need radiator,electric fan, fuel pump, fuel filter, fuel fittings and driveline mod. I plan on Installing the wiring on Monday or Tuesday which I've already sorted out so It's just a matter of putting a hole in the fire wall and popping it through. Since I pulled the clutch master cylinder out this is where I'm gonna pop the ford wiring through.
