when relocating gas tank
insane@hackermil.com's avatar
vegasyota94's avatar
vegasyota94
for those of u who have moved ur tanks to the back of the bed/frame... what are you doing with the fuel lines? Are you just getting longer ones, or are you hooking them up to the stock space, and just running them to the rear?
3tcrob
The easiest thing to do is to move your tank to the rear and replace the rubber lines with longer ones, the rubber line will hook up to a hard line at the rear of the cab run under the cab to the firewall and turn it to rubber again
HTH
vegasyota94
ok kewl.. i was just wondering if u just used like clamps at the stock place where the tank is.. but i will just run longer lines from where the stock ones hook under the cab....
holcombe347's avatar
holcombe347
im sure using little hose clamps on the lines wouldnt be a bad idea. you can get the mini ones for that size line at vato zone for like 3 bucks. for a pack of 4 or something like that.
krayla
So basically all there is to moving it is extending some gas lines and some wires correct?
kdcgrohl's avatar
kdcgrohl
well, theres that pesky mounting to worry about too...
vegasyota94
yeah i already got a place for it.. and i got a chance to lay on the ground and check out where the hoses clamp at... fuckin easy shit..
also got most of my 4 link installed.... had to make it first, but that only took a hour or so... mounting it sux, cuz once again i hate to lay on the ground and weld..
krayla
Hey vegas when you gonna make a uc thread for your ride too?
vegasyota94
hell i dont know...i will have to find all my pix.. i dont really like to stop and take pix, but let me get it driveable, then i will post all my pix up from begining to end,
krayla
Hey what kind of welder are you using to bag your truck?
