switchbox wire diagram
insane@hackermil.com's avatar
vegasyota94's avatar
vegasyota94
i got a 10 switch pre wired from seth.. need to know what goes where.. im running 4 valves... so whatever the best way to hook this shit up..
seth.. help.. lol
holcombe347's avatar
holcombe347
your only running 4 valves?
either way, find the front, back, side, side, toggles and use a testlight with the wires and test up's and downs. for the valves. it shouldnt be too hard to figure out.
your only going to use 2 of the 4 switches there so just choose which two you want to do what. becareful though cause some of your other switches wont work, and others will work partially. so just wire it so the two you choose work as up and down for front and rear.
kdcgrohl's avatar
kdcgrohl
look inside that fucker and see what color wire is on the switch you wanna use. remember the pin on the top of the switch will be for when you push the switch down and vice versa.
