how can i fix this shit...?
b-boybrush@hotmail.com's avatar
limon's avatar
limon
my cluster broke. now i don't know how fast i'm actually going. so i need to fix this. or if is possible... can i swap the sr5 cluster in my yota...????
m_i_zombie
is it the cable or the actual speedometer?
Th swap should be no problem at all, you may have to change the oil and water temp sending units to mechanical ones for it to read correctly.
glhturbo
v6 to v6, 22r to 22r.... unless the tach wont be right- there are ways to mod it tho
and make sure its cable or electronic speedo like he said
limon's avatar
limon
i'm not sure what it is...but i think is the cable cus everything elses works fine except the speedometer.
m_i_zombie
More than likely its the cable, thats an easy and cheap fix.
holcombe347's avatar
holcombe347
yeah dude, they are pretty cheap..i just had to get one cause mine was squeeling really bad. it was lik $20 at advanced autoparts.
limon's avatar
limon
can i find this in any auto parts store? n where is it located in the truck?
m_i_zombie
Yes you should be able to get this at about any auto parts store, they may have order it for you. It attaches to the back of the instrument cluster goes through the firewall and down the side of the transmission into the transmission. Should only need your hands and maybe a screwdriver and pliers for this.
