nook
From what I can recall in the early 80's Toyota built 2wd pickups with 3/4 ton and 1 ton ratings, they used the standard 8", 5 lug , 1/2 ton rear axle only increased the number of rear springs for the extra weight rating.
In the mid 80's, I believe it was late 85 they came out with a full floating 1 ton rear axle with dual wheels, it had a large center hub with a large 6 lug bolt pattern specific to that axle only and not the same as the 4wd. it had extra gusseting for strength, and had sway bar mounts welded to the rear facing axle tubes.
Around 88 they built the true full 1ton cab chassis unit that had the full floater rear axle along with a larger front hub assembly that used the same large pattern 6 lug front wheels, UHaul used a lot of the chassis's as did most all the motorhome manufacturers of the time.
