General Discussion \  need help
need help
General Discussion
views 990
replies 6
assdragginsdime   +1y
im lookin for pics of raised clutches in a 89-95 bodydropped yota. Preferably pics of under the dash, adn how it hooks up to the pedal. i also need pics of modified steering shafts.
kdcgrohl   +1y
my steering shaft needed no mod.
m_i_zombie   +1y
This is an example of what you can do, its from my 87.
I sectioned it to fit the wheel tubs, moved my booster over 3in. I also relocated the pedals by sectioning and shortening, it put them close to the stock position.
assdragginsdime   +1y
mine lays right on the control arm mount,.. im assumng you have like tubulars or something? im running stock arms for nwo, and on the front control arm mount. the steering shaft is hitting, and the suspension isnt even laid out. so i need to figure somethin out.. ill post up some pics.
twisted minis   +1y
Notch the arm.
kdcgrohl   +1y
have you already beheaded the shock mount? if not, that would be your problem.
i am running tube arms. if its hitting the mount and not the arm tho, cut it like so.
assdragginsdime   +1y
i honestly havent done anything with the front suspension yet. But i will be starting on it this week. It hits on the arm itself.. But right above the bolt that holds it to the frame.. i will take some pics when i get up there. i blew the motor in my daily, so im tryin to figure out what im gonna do lol
