airgasim
Thats it!
Prior to chopping out the leafs you need to set the truck at a nominal setting ,usally ride height.
This will allow you to set up any link setup at a perfect pinion(manufactures)
once its at ride height set the lower links parallel to the ground.
The 3rd or 4 links center the axle and limits its movement side to side.
Other times called a locating device.
The 3 link is perfect for most trucks and can leave you with plenty room to work unlike four or six links.
Use a 220 welder for suspension welding and make sure it penitrates good
Remember function 1st ,looks 2nd.Dont skip something cause you think it dont look good,there might be another way!
