General Discussion \  wiring questions
wiring questions
General Discussion
views 762
replies 6
m_i_zombie   +1y
Ok I need some help with wiring in the engine bay and under the dash. I have either overlooked, misplaced or simply cannot for the life of me figure these out. This will apply to the 84-88 22r motor and body. I have tried going through the manual and some of the color codes do not match what I have so thats why I am asking.
Engine bay:
What color wire does the the ac compressor connect to coming from the main harness? or is there relay?
I am adding the intermittent wipers I have the intermittent box and 2 of the plugs connect to the washer pump where does the 3rd plug into ?
I have swapped to a Weber carb and I want to use the factory choke power wire in the harness. Any ideas on which one it is in the plug?
Interior:
For the life of me I cannot figure this one out, LOL I know I am going to be saying i'm a dumbass but I'm gonna ask anyways. What wires connect to the brake light switch on the pedal assembly? I know it should be 2 female terminals but I cannot find them on my harness.
its been almost 2 years since I had this torn out so i've forgotten somethings and I don't have the parts truck anymore to rob or make reference to. Appreciate any help you can throw my way.
m_i_zombie   +1y
can someone at least tell me which wire connects to the ac compressor????
kdcgrohl   +1y
single wire round plug. i think. dont know color.
m_i_zombie   +1y
my ac has a single lead, square plug coming from the compressor. I need to know what color wire from the harness connects to it. The ends have been butchered off the wires from previous owners.
holcombe347   +1y
i think i have a square plug and if memory serves its a white wire with a stripe on it.... ill double check tonight and let you know.
kdcgrohl   +1y
according to my haynes manual, earlie models use a "bw" for the magnet clutch. "bw" should = black wire white stripe.
according to the same book your stop light switch should be connected to "gw", green wire white stripe.
and the heater choke coil should be a "y", yellow.
sorry i dont have that model truck to look at to make sure, maybe that would be a direction anyway...
m_i_zombie   +1y
I got the the brake light switch and the carb hot wire working yesterday.
I just need to know what the color code is for the ac clutch and what guage it is. Like I said earlier the harness has been butchered to hell, There is a BW wire seems to be of 10 guage and one wire of about 14guage. I think its safe to assume the BW that is 10 guage goes to the starter as it says in the manual??
