Mazda Trucks \  Mysterious oil leak
Mysterious oil leak
Mazda Trucks Make Specific
views 174
replies 0
following 1
diablo   +1y
I've got an oil leak and I can't figure out where it's coming from. It appears to be coming from the area around the fuel pump at the rear of the engine. I checked the gasket between the fuel pump and the engine block, as well as the valve cover gasket in the rear. They both are dry. The oil seems to be blowing against the fire wall behind the fuel pump and then running down under the truck. It's hard to tell since it only seems to leak when driven at high speed. I'm baffled. Does anybody know of any possible issues with the 2.2L engine leaking oil from this area?
