Air Ride Suspensions \  What else will I need? Air Help.
Air Ride Suspensions Q & A
views 245
replies 0
following 1
lowchick   +1y
- 2 VIAIR 450 COMPRESSORS - 8-GALLON 8-PORT AIR TANK- 8 GC 3/8" VALVES 250 PSI- 10 SWITCH BOX - PRESSURE SWITCH - RELAY FOR COMPRESSOR - 2 DUAL NEEDLE 200PSI GAUGES - 1 SINGLE NEEDLE 200 PSI GAUGE- 50' OF 1/2" DOT AIRLINE - 50' OF 1/4" DOT AIRLINE- EAI AIR CYLINDERS WITH FITTINGS AND EVERYTHING WITH THEM
This is an exact list of what I have for my air that i'm going to put on my car. I was just curious if and what else I will need. I want to have everything for it so when the my friend installs it for me that everything is there. What wiring and anything else I might need. Also, where should I get anything else that you might mention? Thanks for the help.
