okay i finally got my 55 buick
1 following
johnz
only prob is the starter is acting up..if none of you have had one the starter switch is on the gas linkage..heres what is happening there is a relay prior to the solenoid and it clicks and give power to the solenoid like it should but the starter doesnt turn..but when i go under the car and manually actuate a rod the starter turns ..the solenoid has three wires going to it one from the batt big wire , one from the relay and another off the batt distro block..is it possible i have these two small wires reversed?? the solenoid is new??
