Chevy/GMC Trucks \  1998 s10 ext bag install
views 114
replies 0
following 1
dropbottom   +1y
ok guys,you all have been so helpful the last couple days,but i have another question,i have the bags on all four corners and yes it does lay out on my 20s i have in the rear,up front though its like it does not lift high enough,i have only tested the bags with 90 psi from my little air compressor and tank,not with the valve and my viar compressors,its funny that when i lift the front of the truck with a jack the lower control arm does not come down,so i filled a bag with air from my compressor and as it filled the bag with air the lower control arm and the tire came down,but as i released the air the tire and bag went back up,with the front end in the air no weight on the tires,does anybody know whats going on is this normal,if not what did i do wrong,i have 2500 lb bags up front,on 18s,with floater bag cups and 2 in. chassis tech drop spindles with stock upper and lower control arm,i dont have the schocks mounted yet,could this be why,please any help is greatly appreciated,thanks jeff
