couple welding questions
1 following
rob_lervold@yahoo.com's avatar
Rob Clayhill's avatar
Rob Clayhill
first off, ive never even tried to use a welder until lastnite so i have a few things to ask.when you have your filler piece to shave a handle or somthing, where do you put the filler? directly inside the hole cut out or do you make the filler a little bigger and put it to the backside and weld it that way?also how far apart should the tack welds be or should i just end up with a solid weld all the way around?
