Ford Trucks \  Ranger Wiring Problems.... HELP!!!!
Ford Trucks Make Specific
views 271
replies 0
following 1
rangerdragnbody   +1y
I have bodydropped my ranger, so the interior has been all taken out. I'm trying to get the fuckin thing back together and I can't get any power to the cab. The battery is hooked up and grounded properly. The factory ground is grounded, and the power wire to the engine and the fusable link are all connected to power. There is a brand new starter solenoid in the truck, and those 3 big plugs on the driver's side are plugged in properly. Even though the dash isn't in, the steering column bracket is properly grounded. All of the fuses in the fuse box are good, and the plugs into the ignition are in properly. What the fuck could this be. I have fucked with this shit all weekend and I'm really getting pissed off because this thing needs to roll for greenville. Nothing in the cab is getting power, or the headlights, taillights, fuel pump. The starter solenoid is getting power though. Does anyone have any suggestions, or if you had this same kind of problem, please tell me what you did to fix it, b/c I may have overlooked something. Is there suppose to be a fusable link connected to the battery cable? There is like this gray stiff wire and that is what I thought it was. By the way the truck is a 97 Ford Ranger 2.3l 4cyl. Thanks!
