Air Ride Suspensions \  anyone installed cool-ride frt on 90-chevy C1500 ?
Air Ride Suspensions Q & A
views 130
replies 0
following 1
Lowest454   +1y
I'm in the middle of installing cool-ride front cups in my 90 chevy C1500 454ss, got the shocks & springs out, went to install upper air bag cup into inside upper part of frame rail where old springs were and on the bottom of the inside upper rail there are triangular wedges of metal centered where the inside diameter of the coil spring use to sit to keep it from moving, the cool-ride air bag cups do not totally fit around these triangular wedges causing the cups to sit off center. do you have to cut these wedges out, if so I'm gonna be very pissed, cause there's not alot of room to get a die-grinder up inside that frame rail. any help would be much appreciated !
