My Project Pix
insane@hackermil.com's avatar
My Project Pix
vegasyota94's avatar
vegasyota94
ok well ive been fucking with this damn truck for awhile...
got the bridge kit done, got the front done... not cutting out the inner fenderwells as of right now so thats why its not laid out in front..
the rear needs the bottom bag brackets put on, and the 4 link.. also need to cut off the leaf spring brackets.. thats what its laying on right now..
maybe later today i will cut the bed... i donno yet... check em out..
and seth dont be a dick about it... im not as good as u thy master.
toy-so-low
looks good man better then wat i could do
twisted minis's avatar
twisted minis
Dam dood.
vegasyota94
damn what?
lol
dude the bags i got in the front, are like 2 inches wider and like 3 or 4 inches taller then the ones i got from u.. it gets hella lift too
twisted minis
Slam bags are known for not expanding width wise as much as others by a long shot in some cases. And usually get more lift.
You say you get a lot fo lift, but does it lay and get a lot of lift? You can lift the frame 12" off the ground, but only be getting 8 inches of lift, you know.
And also, you should have welded the lower bag mounts in first, in the back, so that the bags are botomed out completely when laid out, because go dknows you need as much lift in th back at a 1:1 ratio. You'll get 5" lift total.
vegasyota94
yeah i know i should have done that... i might be doing a bar behind the axel.. and doing brackets from axel.. like yours is setup..
so these slam bags will lift hella high?
twisted minis
They will do alright. I would put the smaller bags in the front. They slams don't balloon as much, which means less chance of rub through. I'd put the bigger ones out back where theres less chance of them rubbing anything.
vegasyota94
ok i wll check that out.. since i dont know how tall the slams will go, i will hook them up to an AC.. i know how tall the fronts go.. they got fucking tall.. lol
and yes i had the fronts aired up and it goes to stock height or a little taller aired up..
i will figure it out...
thanks for the help man
vegasyota94
got farther today..
twisted minis
Nice. Lmao @ HB.
