Air Ride Suspensions \  Shitvic needs help
Shitvic needs help
Air Ride Suspensions Q & A
views 116
replies 0
following 1
98lows10   +1y
here is the prob. its with my daily driver (97 4 door civic www.cardomain.com/id/tuckin18z )
the setup is 8 3/8" SMC, two 3 gallon tanks, a blowjax compressor and 10 switch box (might be from aim) and i have no clue what kinda cylinders (no name on em anywhere, they are silver.)
i have had this about 2 months now and got it the way it is. the rear right would leak down, lose pressure, drop, whatever u want to call it when i would hit huge bumps. that was livable and understandable. then one day like 3 weeks ago the front right started doing the same thing, but without hitting bumps i would air up and it would leak right back down like the valve would be partially open. so i heard that a 6" or so piece of airline on the dump would help because of the vavles needing back pressure to open/shut right. that worked for a while, then started doing it again. now the past few days the front right started doing the same thing. if i fill the tank to full pressure (175PSI) and air up it seems to be fine to drive like 5 minutes, then after hitting some bumps and shit it will drop down ( the right front, left front, right rear) sometimes it will be the whole front goes down, or just one corner.
this shit is pissing me off to no end. SMC's are rated to 150 correct? have i fucked up up runnin at 175? are there seals on my cans that could be shit. i am going outside now to try to clean the vavles and look at it more, i was just wondering if any of you have had similar problems and what u have done to fix it. its my daily driver and rode good on the shitty roads around here up until it start this bullshit. sorry for the book and thanks for anyhelp
