Air Ride Suspensions \  Leader hose on Compressor
Air Ride Suspensions Q & A
views 87
replies 0
following 1
trader   +1y
Ok guys, another problem has arose. The fitting coming out of the compressor connecting to the leader hose has broken. There is obviously a small tag on the leader hose stating that you should not tighten or loosen the fitting because it has been done so at the manufacturer. Well, since the fitting broke, I was wondering what options I have with this. Can I just use a new fitting and hose? Does this really matter? What should I do? I can't use the original leader hose b/c the fitting is broken off inside of it. Not to mention that the fitting does not even remove from the leader hose.
I'm at a stopping point right now in the project so I really need to know what's up. Thanks guys. It's crunch time.
