Mounting Valves?
1 following
Mounting Valves?
trader
Ok, so what are some ways that you guys have mounted your valves? I mounted mine to som small plates that were welded to the frame. Well there was a big problem there(duh) when it came to wiring my setup. The valves were grounding themselves out. So what I did was used some plastic between the metal surfaces to keep them from doing so. I don't reall like how it all looks now b/c it doesn't look as clean. So I was wondering, what are some of the ways that everyone else does. I'm here in the Midwest(st.louis) and don't see too many Minis in person to check it out.
s10
last post by baha +1y
