Mini Truckin General \  air ride technologies valves are sticking HELP!
views 154
replies 0
following 1
built to drag   +1y
Well my project dailey driver has caused me more grief than it is worth. So far the the push in fittings leak in the front, the 50 dollar switch box is wired wrong in side, so dont buy one, the pressure switch doesnt do shit. And to top it off now the valve is sticking. Did i mention i drive it every day. Here is what it does, i can lift the truck up no problems but wwhen i go to lower it only comes down on one side. It is air ride technologies manifold, its basically 4 two ways in one unit. The catch is that it only does this when there is over 120 lbs of air in the tank. I know that with some valves when you have equal airin the tank and bag this can happen but that is not the case here. Believe it or not i traded these valves for my parker golds because i thought they would be easier to mantain and look cleaner. I dont know what is wrong with this valve or if it can be fixed by adding lube to it or some thing....any help would be great
