Air Ride Suspensions \  GC valves malfunctioning???
Air Ride Suspensions Q & A
views 95
replies 0
following 1
soufside suspension   +1y
I just finished my setup on my 72 Pontiac convertible. Its a fbss fast bag setup. I mounted the valves as close to the bags as possible, and it moves real fast for such a heavy car. My problem is that sometimes when i dump, the valve seems to hang open. If i just tap the switch to level the corners or even the front or back or sides, it keeps dropping after i release the switch. A guy i know that has these same valves in his truck said he had to put a piece of airline on the dump side a couple feet long to make some back pressure to push the valve back shut. Anyone had this problem before? What did you do about it? The car lays frame really hard cause when you dump it it slams down almost instantaneously, its hard to just get it to drop a little. Should i slow down the dumps somehow? Any input would help before i go buy new valves.
