BAD LEAK!!!
1 following
BAD LEAK!!!
dray504
the front of my car leaks down really fast, from what i can tell i believe the air is leaking back through the fill valve and back into the air tank(due to the front doesn't leak down when the compressor is on), what is the best remedy to fix this problem(replace valve, clean valve, put in a check valve between valve and air tank, etc.) does anybody else have/had this problem. Thz
s10
last post by baha +1y
