Air Ride Suspensions \  Sotck a/c pump to compressor?
Air Ride Suspensions Q & A
views 86
replies 0
following 1
drgndly   +1y
Alrite i was reading the topic of the stock a/c pump to compressor. My electric comps were shit. So i went n got everything to do it. Oiler, filter, Air trap with a filter in it. Tapped the oiler into the low pressure side. Tapped 3/8 hardline into the high pressure side and ran it to the tanks. Started up the car and it might have filled to 1 psi and thats it. Theres air in the line cuz i unscrewed the water trap and air started hissin. Air is getting to the tanks, no kinks in the lines. Though maybe cuz the line to the tanks still ran through the condenser that that might be the problem. Unhooked the high pressure line from that a/c pump and it just doesnt seem like theres enoguh pressure there to fill anything. Ive got a 96 dodge avenger with a v6 in it and 2 five gallon tanks. It had cold A/c before i drained it to do this. Would the pump be bad or is it jus not strong enough? What is this Oriellys i read about in the other post? Should i try gettin a york 210 or just see if i can get better electric compressors?
Matt
