i've got a 90 model single cab....its got 20s on it ....i want to body drop it to the rockers.......i need some help moving the brake booster and clutch reservoir?
Post was last edited on Feb 12, 2007 07:45. Edited 1
time.
guilty by design
dam 20s??? Good luck to you sir, im skinning my hood with a set of 18s.
twisted minis
20s on the rocker will stick out of the hood unless you raise the fenders.
papa smurf
how many inches could i go without rubbing the hood too bad?
twisted minis
You could probably cut 1/4" off the bottom of the pinch weld. But don't quote me. Most people just go to the pinch weld.
spicy
225/30/20 YOU SHOULD BE OK TO THE ROCKER
twisted minis
My friend has a 4Runner on 225/30/20s. Hes to the pinch, and has about 3/8" between the top of the tire and the top of the hood. The pinch weld is 3/4" tall. My calculations = hole in hood.
toyotaman89
hole in hood BAD.
guilty by design
I remember seeing a black pre-taco at indy this year on 20'' AR Casinos... dont remember if he was on pinch or rocker tho.
holcombe347
if its the same truck, i believe it was to the rocker but he had done something to the front fenders to make them clear....i dont think he sectioned and raised them but like he raised the whole front end up enough to just clear the tire. its hard to tell anything was ever done.
