front crossmember drags
PS
papa smurf
i had stock rims w/ small tires and the crossmember between the lower arms dragged like a bitch......the 2 bolts on each side fell out..so i welded the bitch in.......then i got some 18"s. The arms and crossmember were off the ground then.......TO the point: now i have some 20"s I'm about to throw on. Will that shit still drag?
Post was last edited on Feb 12, 2007 07:47. Edited 1 time.
holcombe347's avatar
holcombe347
if you had 18's on it and it didnt drag, the 20's will lift it up a little higher because the wheels are bigger so if it didnt do it with 18's it def. shouldnt do it with 20's.
PS
papa smurf
thanks fucker
guilty by design's avatar
guilty by design
Not nessesarily. Changing WHEEL sizes doesnt mean itll lift the truck any. You need to know the difference in the overall height of the tires then divide it by 2, that will tell you how much it lifts the truck.
