Wheel Locks
Wheel Locks
stll2hi avatar
stll2hi
Anyone got a locking lug nut remover?? I've seen a few different sockets on ebay, but they're like $20. I just need them to get off 2 lug nuts. Any help??
stll2hi avatar
stll2hi
Sorry, bad forum to put this under. My bad.
twisted minis avatar
twisted minis
19 MM deep socket. BFH.
kdcgrohl avatar
kdcgrohl
sears sells a set of spiral removers that will work nicely.
cnudrln avatar
cnudrln
my advice goto walmart spent 10 on 2 sockets use them and then take them back.
kdcgrohl avatar
kdcgrohl
thats just wrong. morally reprehensible. disgusting. you should be shot. but yeah, i've done that too....
stll2hi avatar
stll2hi
LOL....by the way, works at Home Depot also. Anyway, so a 19mm will work. I'll give it a shizot. Seth, what is BFH...??
twisted minis
Big Fvcking Hammer.
yodaforce avatar
yodaforce
When I was managing a Super Shops store, we ran into this problem alot when installing new wheels. You just have to get a socket that barely fits over the face of the locking lug, tap it on with a hammer until it "bites" the lug tight enough to get a rathet on it and break it loose. Once it is loose tap the sides of the socket to get it off the lug, then spin it off the stud. You end up with socket that is still perfectly good for it's intended use, and in most cases, a locking lug that is still good should you ever come across the key for it!
diabolic kustoms avatar
diabolic kustoms
you could also just buy the matching key and still use them later. I got a whole set of keys for this problem. Go to the junkyard and look for keys in the gloveboxes and trunks. There really is only like 5 or 6 different locking nuts. Then there are a few that require a special socket instead of a key. And when all else fails snap on makes the best remover tool
