sick running toy HELP!
1 following
disolve
hey question i dont really have a good mechanic to go to and i dont trust just any joe blow so if anyone knows any good mechanics in south oc or knows of a good website where actual mechanics answer questions in forums that works anyways if anyone can help heres my problem..
temps seems to be running hot head gasket is fine after time radiator fluid runs low its been drained nothing is leaking nothing out the exaust my dads seems to think its might be the water pump even tho i have no leak. next it doesnt seem to always idle at 750 itill drop aslow as 500 usually around 600-650. and sometimes it will idle perfect at 750. also if its been running and warmed up say 10 minutes and if i get gass and start it it will die out unless i rev it a lil bit once or twice then its ok. and last the past few days when im driving around 40-55 in that range it sputters like it loses power rapdily quick only in those speeds then it gets it back and it doesnt always do that. ive been told its a bad throttle body due to the k&n cleaner having to much oil so it clogged and it just ruined it. anyway sorry for the long message but if anyone knowsplease tell me it also needs a new clutch so if any of these problems could be from this please let me know.
