Air Ride Suspensions \  Installed some Canovers on a 2000 3.2TL...
Air Ride Suspensions Q & A
views 131
replies 0
following 1
AVTekk   +1y
Well Im at it again, but this time with Canovers on a 2000 TL with a Lexus front end. In case youre not familiar with Canovers, they are air cylinders from Japan, with adjustable mounts, and adjustable valving so you can set how soft or hard they ride. They are very good quality, but there are some fitment issues, as with most aftermarket parts. The rears fit ok but needed 3 shims per side on the bottom to take up space. The fronts fit on top as well, but the valley in the mount did not line up with the bolt in the fork, so I had to machine that out. Sorry, no pics. Another big issue is that the spindles sit on the sides of the cans when aired out, and Im not happy with that at all. I moved the brake line bracket down and machined out the back of the spindle as much as possible for the time being. Heres some pics..
Trunk install, everything done by me. The blue LEDs on top of the battery is a built-in volt meter on the poss terminal..
Switch install with tank gauge. Those doors fold up to cover them when not in use..
Car pics:
Let me know what ya think..
