Air Ride Suspensions \  Will this work for a 2link?
Air Ride Suspensions Q & A
views 75
replies 0
following 1
whynotfab   +1y
Edited: 10/10/2004 12:08:27 AM by LowNFToy
first of all which would be better 2x2, or 2x3 tubing? im either going to mount the front of the bars by building new hangers inside the framerails, or by building a crossmember with 4 tabs facing towards the axle, which would be better?
then since im not good at overhead welding yet, but i can get good penetrating welds on flat surfaces, could i use this to weld my bars onto, then bolt it to the axle,
what is the welded nut for on the clamp piece? i could maybe also weld along the top of the clamp to be safe too.
and then run the panhard bar of course to be safe.
i only ask this because it looks less time consuming than taking the rearend out, flipping it upside down so i feel more comfortable welding, and it would be removable anytime. let me know what you think, suggestions or things i could change let me know. thanks
