air over juice questions
1 following
vuducru avatar
vuducru
Dose any one have a set up where you use airbags to push hydraulic cylinders? I was wondering what size ports you have on your cylinders and how fast is it? I'm planning on running a 2500lb bag with 3/8" smc valves pushing two 4" cylinders with 1/4" ports coupled to one 8" cylinder in the front with a 1/2" port with #8 hose. I will run one of these configurations per side. Dose any body think that I will have lag becase of the two 1/4" ports not having the same area as the 1/2" port or lag in general because the ports are too small for quick fluid transfer. I'm trying to achive the same speed as a normal 3/8 valve would lift in the front of a mazda b2200. Thanks for your help.
