Mini Truckin General \  Viair Question on Electrical side of Compressor
views 166
replies 0
following 1
Jplasse   +1y
Alright, I have gone through 2 Viair 450C's in the last month... They will be runnin just fine, and workin all great n then they will just shut off (no not because of being too hot). I fixed the first one because I had an extra compressor lying around by putting a new "electrical side cap" (piece that has power n ground commin out of it). I opened my compressors up and inside on the ground side terminal is a small cylinder, diameter of a dime or so that is the problem. Used a continuity (sp?) tester on it and its good until the cylinder, then comming out the other side its dead. Anyone know what that cylinder is? can it be replaced? and what may be causing the problem? Thanks in advance.
