Audio/Video \  which amp is better
which amp is better
Audio/Video Q & A
views 125
replies 0
following 1
southern   +1y
Phoenix Gold Octane R8.0:1400 Watts x 1 800 Watts x 1 Peak (2 ohm mono) High efficiency Class "D" monoblock amplifier 18dB variable LP crossover 18dB variable subsonic filter Low Pass Level port (LPL) Dimensions: 14.75L x 10.875W x 2.25H Grained aluminum insert Carbon fiber badge, backlit with blue LED Optional neon inserts for all amp models Overload and comparator circuitry Full range thru output Remote monitoring Display (RMD) port Twin "T" bass circuitry at 45Hz Load stability: 2O Stereo, 4O Mono
OR
Class D Design 1 Ohm Stable New 20th Anniversary HiFonics Heat Sink Backlit Electro-Luminescence Logo Illuminated Maxxsonics Endplate Logo Exponential Vari-Power Supply (EXVP) New Ultra-Fi MOSFET Outputs 24 dB / Octave Variable Crossover Subsonic Filter Remote Bass Level Control Amplifier Type: Mono RMS Power: 350W x 1 @ 4 ohms RMS Power: 700W x 1 @ 2 ohms RMS Power: 1000W x 1 @ 1 ohm THD at Rated RMS Power: 0.08% Speaker Level Inputs: No Preamp Outputs: Yes Built-In Crossovers: LP Bass Boost: 0 - 18 dB Frequency Response: 20-250 Hz Channel Separation: n/a Signal to Noise Ratio: 90 dB Fuse Rating: 60 amps
thanks for any opinion
