rs-62's on a F-150
rs-62's on a F-150
F
FrAmEdOn22s
There are a set of cups kp makes for the f-150 that hold rs-62's in it. the thing is rs-62's are compatable to 2500 right? So do you think i will get enough lift with the slams and those cups. i am on flipped balljoints and 22's.
jmn444's avatar
jmn444
Originally posted by bertristerf150hd
do what navi said slam is just a little confused. take the computer out of the cab fill in the hole for it, move it in the engine bay, right side. for the left there are 3 wire harnesses with a total of 76 wires. there are several ways of doin it. you can put a plate in for like 3/4 of the hole moving all of the wires to the top, i believe that is what slam did, you can take a piece of sheet metal and drill 3 holes in it and extend the wires 15 inches, which i did, or u can cut the section around it and move it over as far as the plugs in the cab will let u, i found this out after i did mine, which is easier and makes more sense.
got any pics of what you did? and does the battery need to go in the bed too? if anybody has some progress pics of what they cut out and what they moved for 22's w/ 265/35's on them, please post them up!
