Mazda Trucks \  Weber carb install questions
Mazda Trucks Make Specific
views 109
replies 0
following 1
mazdizzle   +1y
I just put a weber carb on my 88 b2200 today and it runs great but I had a few questions. There are 2 vacuum ports on the pass side of the carb which one is for the advance on the distributor? I used the one towards the rear and plugged the other one and it seems to be fine but I just wanted to make sure that was the correct one. And should the other one be plugged or should I run a hose to one of the ports on the manifold. I took all the computer wires out that come through the pass side of the fire wall to clean it up. Other than the windshield wipers are there any other wires I need to keep from that harness? Right now I don't have any wires comming through there and everything seems work ok. There was 1 square plug I believe 3 or 4 wires by the battery that ran across the rad support that I don't know where it went to. Any help would be greatly appreciated. Thanks
