Air Ride Suspensions \  Need Help Decided.. Opinion Please...
Air Ride Suspensions Q & A
views 101
replies 0
following 1
DraginAssEnd   +1y
Ok, well I have $1200 bucks leftfrom my insurance money. I have to options, I can get my car shaved & primed a tight ass color. OR I found an air ride kit 4mo old for $1300It Includes:*Smoked 10 switch switchbox with a seperate control for Pancake (all 4 up and down), Front Left, Front Right, Back Right, Back Left, seesaw (front and back back and forth like a teter toter sp?) front, back, left and right, all labeled on the switchbox. $80.00*Dakota digital gauge and senders with tank pressure sender (tank pressure sender not shown in pics, the sender will be on the top port of the tank where you see the needle gauge, and on the gauge on the dash the tank pressure will read where it says "air psi"). $325.00*8 port 5 gallon air lift tank. $55* Airlift/easy street front air struts. $550*Air ride technologies rear sleeve bags. $350*8 SMC valves 3/8 inch. $320*Viair 380 compressor $225*Pressure switch turns compressor on when it gets down to 115 psi and shuts it off at 140 psi so you dont have to worry about turning the compressor on and off. $25*Water Trap so your tank and bags dont get the condensation your compressor puts out. $10*$100 worth of brass DOT approved fittings*$50 worth of 1/2 in airline*$50 worth of wiring*$25 worth of stainless steel hardware.*$7 DIN cover with gauge mounted in it.
WHAT WOULD YOU DO...???
