Air Ride Suspensions \  Brake lines after changing out axel
Air Ride Suspensions Q & A
views 80
replies 0
following 1
jmurphy   +1y
OK here is the problem that I am running into. I changed the axel to a toyota withe brake lines on the passenger side. I removed the valve in the back and now I am only running 1 brake line not 2 lines. This is the same side as the exhaust. Now with it bagged the exhaust is right next to brake line. On the way home today the brake line popped and brake fluid was all over everything. I never had this problem with my other Mitsu but I did not change out the axel. Is it the heat. Any help will do. Thanks.
