Audio/Video \  FIBERGLASSING REAR DECK
Audio/Video Q & A
views 148
replies 0
following 1
rockstar-c10   +1y
IM GOING TO FIBERGLASS THE REAR DECK OF A 98 CIVIC 2 DOOR,IT WILL HAVE FOUR EMININCE 6.5'S IN THE REAR,ILL PUT TWO FACING DOWN IN THE FACTORY LOCATIONS,ONLY THEY WILL BE MOUNTED ON TOP INSTEAD OF UNDER AND THE OTHER TWO INBETWEEN FACING FOWARD.I HAVE THE WOOD CUT OUTS AND MOUNTED THEM THE ANGLE THAT I WANTED BUT HOW DO I HOLD THE FLEECE TO THE PANEL?CAUSE IT ONLY NEEDS TO BE FIBERGLASSED IN THE MIDDLE THEN BLEND IN TO THE THE PANEL,DO I STAPLE THE FLEECE TO THE PLASTIC OR HOT GLUE IT?ALSO SINCE THEY ARE ONLY MIDRANGE I ONLY NEED TO ADD RESIN(W/HARDENER)TO THE FLEECE I DONT HAVE TO USE MATTE RIGHT?THANKS
