Mini Truckin General \  HELP! Electrical Problem
views 102
replies 0
following 1
whynotfab   +1y
today i had my truck running, which ive had it running for a while now..and have been starting it/letting it run for like 20 minutes each day that i work on it.. even with the compressors running for a while. today i had it running for maybe 5 minutes, turned the compressors on maybe for a minute and they suddenly sounded like they were crapping out.. so i turned everything off, checked the connections for the compressors. then i started my truck back and kicked the compressors on.. and the whole truck was about to die so i shut it off.
i went back to my wiring and a wire i used to extend the fuel pump wires, one of them was burned all the way i had extended it. the wire i had used was half the size of the original fuel pump power and ground, so im thinking that was the reason, because i couldnt find anywhere it could have shorted or arced. if anyone can help me out id appreciate it.. thanks
