BD and wheel size
BD and wheel size
loweredtoy
ok is it possible to BD a 90 yota to the rockers and still use stock tires? I was just curious if they would be to big or i would have to run a smaller tire if i was to get the urge to do it. thanks
twisted minis's avatar
twisted minis
Stock tires are equivalent to 18s. You will have no problems, you could run bigger tires.
loweredtoy
so something like 215 70r14 actually is the stock size tire. So when BD to the rocker what is the biggest wheel you can run. I just like the look of stockers tucked up in the fenderwells. thanks for the help
phatboislim
my 18 w/ the 225/40/18 on it was like 24-25" in diameter..chk ur 14 to chk, but im w/ seth on this one, basically same thing, just not as wide
twisted minis
Yea, my stock tires are about 1/8" shorter than my 215/40/18s. You can run 19s on the rocker just fine. 20s if you run small ass tires.
loweredtoy
alright, i'll probably run stockers for a while if i can go through with it. If things pan out this might be my spring project. BD to rockers, stockers, 2pump hydro setup, everything shaved, backhalf, whatever else i encounter
johnny5's avatar
johnny5
you will have to modify your fire wall thou. i have stocks on now with a bd and they hit my fire wall lol
loweredtoy
yeah, i already "massaged" my firewall for just the drop
Related Discussions in Yota Exterior
