front wendsheild removal
N
tuckinlugs05-06
whats best way to get it out iv herd piano string or weldin wire what is easyest
truck action's avatar
truck action
There's a tool with a blade & tee handle, you can find it at a good auto store. Or check with a auto paint supply.
loweredtoy
any more info on actually how to go about this?
twisted minis's avatar
twisted minis
Razor blade.
holcombe347's avatar
holcombe347
baseball bat?
2fine89
8 pound slege <img src="{SMILIES_PATH}/icon_smile.gif" alt=":)" title="Smile" /><!-- s:) -->
itfell's avatar
itfell
Just go to any parts store, welding wire wont work because it has no ruff edge, its smooth all the way around. Go to any auto store and ask for a windshield removal kit. It comes with wire that has little teeth on it and a straight bar that holds a razor blade on the end. After you buy this you need to take all the trim out around your windshield. Take that long bar with the razor blade and cut through the black window seam shit all the way around it at least halfway through. Once you do that take the blade and slice all the way through about 2 inches on the side of the window. This allows you to then push the wire through to the inside of the truck. The kit comes with handles that unscrew. Unscrew the handles and wrap the wire around the studs. Screw the handles back tight so the wire stays inside and doesnt come loose. When you have the 2 handles back on just move the wire back and forth and it slices right through that window seam sealer like nothing. Your arms will get tired but it does the job.
twisted minis
You can also kick it out from the inside.
loweredtoy
thanks for the serious answer man
twisted minis
I was serious about the razorblade. Thats how mine came out. Glass guy did it with a box cutter in about 40 seconds.
Related Discussions in Yota Exterior
