Harness Bar
N
Harness Bar
3tcrob
Alright I have been toying around with a idea of bending up some DOM Tubeing that will be about a 1" or so below the back glass or lower dont want the top of my seat to hit it,then run diag to the floor right next to the seats then I would have a straight bar run down from the harness bar to the cab floor. Then I would use 2 4-point harness. Could this be spaced off about a 1/4" and be strong enough to flat wall the rear cab?
Thanks
twisted minis's avatar
twisted minis
Flat wall? Like cut it out and sheetmetal it? Maybe gusset the angles on that diagonal bar, and I doubt anythign would twist really. Maybe run one bar forward in the cab while you're cutting it out.
If thats not what you meant, forget I said anything.
3tcrob
Yeah that is what I'm talking about I was going to gusset the angles with the web ones from SickSide, The diagnoal bars would only run to about the midlle of the seat on the side, Just 2 though one on the driver and theoter on the pass
Related Discussions in Yota Exterior
