Removing inner fenders...
shep
I've seen pictures where some of you have removed the front inner fenders. Is there any need to add additional bracing - running from the firewall up to the radiator support? If anyone has done that...got pics?
thanks in advance!
airgasim's avatar
airgasim
If your just bagged on anything smaller than 18",Most guys just cut the inner fender and are done with it.There is still support because the fender support is still attached between the firewall and rad support,but when you run big wheels like mine You got to cut most of the fender support out ,but if you tub it right like seths then your cool .Plus after you tub it nice most guys box everything else in,Those lil braces and shit make a differance.
shep
Thanks Airgasim...
Related Discussions in Yota Exterior
