ecoastdestruction
ok my freind hasa 97 s10, he just got done doing the front set up, hes running 2 sb6's byc lower control arms,and no shocks as of yet. the problem is that its not lifting in the front at all! he has a compressor hooked to his tank and a manual ball valve to raise/lower(just a temp to make sure it works) now when he opens the valve he hears a slight leak comming from the driver side bag but nothing happens. the tank pressure was about 120, which should be plenty. he also said that he took off the air line and he said that there isnt any air comming through. i'm thinking now that because it was in he back yard and its been snowing that some snow could have got in the line a froze,does that sound possible? i'm just outta ideas any help would be fresh-alex
