Yota Exterior \  side mirrors
side mirrors
Yota Exterior Yota Tech
views 990
replies 4
loasfkyota   +1y
so i have the side mirrors that are down on the door but i like the look of the ones that are up in the triangle area next to the glass.
Will those fit on my doors if i drill the holes?
smctoy   +1y
If your taking about the factory "sailboat" type mirrors then yes they will fit. Look on the inside of your door where the factory mirror would mount & there is a small panel that comes off. Remove that panel & youll see where the "sailboat" type fits & bolts too. My truck already had the holes drilled on it so I just bolted mine on.
baha   +1y
Good info! Do you know if you can swap the factory window vend windows for straight glass from another door? Like would it be easier to just swap doors?
loasfkyota   +1y
Baha, that was my plan if the other style doesn't bolt right up haha.
smc, thanks for the info, as soon as i get back out to the shop i'll check it out.
smctoy   +1y
You can swap out the glass & internal door parts...its a pain, but can be done lol. I just changed the doors out from a standard cab on my truck. Another cool mod is to swap out all the manual roll up wondow parts for electric!! There is a company that makes a conversion kit... .
